I've had to use my immersion heaters for the first time recently due to a problem with the gas. The switches got very hot and now one won't switch. Reading threads on this forum have raised some questions about the switches....
I've got a Gledhill tank laid on it's side with two 3kW immersion heaters. Each one is controlled by a switched FCU located near the tank. The 2.5mm feed comes into one FCU, loops into the next FCU, and then exits. I haven't yet studied the CU to figure out what they are protected by - but this was installed in the last 5 years.
Q1: Should the immersion heaters ever be run at the same time (e.g. if I wanted to heat the full tank as quickly as possible), or should I always choose one or the other?
Q2: Should I replace the broken FCU for a new FCU, or swap out both FCUs for 20A DP switches, or get one of those dual immersion heater switches (the last option being linked to Q1)?
Q3: I'd prefer to move the switches about a metre to somewhere more accessible, which would mean a longer cable from the immersion heater to the switches. The cable is currently 1.5mm stranded heat resistant cable, each one is about 1.5m long. The new configuration would require longer cable of about 2.5m to each heater- is that acceptable?
