- Joined
- 15 May 2020
- Messages
- 12
- Reaction score
- 0
- Country
Hi everyone,
This sound is making me miserable, I wonder if anyone can help?
There is a loud humming/foghorn noise coming from one side of the water tank and two pipes next to it. It lasts for one to two minutes and then stops, at different times throughout the day and night. Mostly noticeable between 1pm-12am.
A ball valve was replaced above the water tank but this did not help with the noise.
Radiators have been bled. The pressure of the boiler was under 1 and that has been increased to around 1.3.
Before all these changes, the noise was occurring once every hour. I don't know which of the above actions has caused the noise to occur less frequently (between 2-5 times a day now).
Next to the water tank there are several pipes, and going into the water tank there are several pipes, too. Only two of the pipes that are next to the water tank, but not directly going into the water tank, vibrate. The other pipes either next to or going into the water tank do not vibrate. And when I put my ear next to the water tank, I can hear it vibrating inside, too. More noticeably from the side of the tank next to the two pipes that also vibrate.
The pressure on the boiler has been dipping slightly even though it was raised a few weeks ago- I was told it should stay at a constant pressure for at least a year.
The plumber has said he doesn't think it's ball valve related. The company who deal with the gas/boiler combi have not come out yet to have a look but when they were here- before the plumber- they were the ones who suggested the ball valve needed replacing. Is there any thing I can say to them to point them in the right direction?
Also, the noise does not occur when a toilet is being flushed or when taps are being opened and closed. Even when the boiler has been switched off from the mains, the vibration and foghorn sound still occurs inside the water tank and the two pipes next to it.
There are two neighbours above and next to the flat.
If it was just a few seconds, maybe I could forget about it, but it's the length of the hum- over a minute sometimes- and the loudness, that is so disturbing!
Thank you for all the suggestions, no matter how insignificant.
