You could always do it properly and ensure that does not happen.
And how do you do that?
I could have 4 conductors, and a modern MCB where the screw doesn't directly screw into the conductors.
I can arrange them in the terminal all nice and straight. No kinks. No crossing over. All side by side.
Tighten it up, no movement.
Ah, a loose conductor.
Ok, let's try two side by side. With another two side by side 'on top'.
Bugger. Another loose wire.
Ok, lets try doubling the ends over.
All nice and straight. All the same way round. Can't really be sure if they ARE the same way round, as no X-ray glasses today.
All in all, it's a bit of a faff, when this problem didn't exist as much with the old round terminals where the screw made direct conduct with the conductors.
I am constantly working on existing consumer units, done by others, where I find loose connections. I generally like to make sure all the wires are secure while I'm there, because I'm the last person to be working on that board, and whenever I see an MCB with two, and especially three or more conductors, I tend to give them a gentle tug because I KNOW there is a very good chance they are going to be loose. And sure enough, they often ARE.
I also feel the amount of testing that has to be done on some existing installations means the disconnecting of once secure conductors, only to be put back sloppily by someone in a desperate hurry to do his next job.
Now that would be poor workmanship by the person putting it back, no question really - but he thinks he's putting it back as it was. He sort of is. Only now the wires could be loose if he hasn't checked. You have to check. You can check once, and they appear fine. You can check a second time, only to find they are loose.
Personally, I wouldn't be to offended if an electrician ran one short wire (over-sized in the case of a ring circuit) and joined the three or four circuit wires to a 5 way wago, I really wouldn't.
