If one of your strapper connections has failed then the other switch will only work with the 'moved' switch in one position.
You need to check continuity of the strapper cable between switches:
- Turn off the power.
- Connect the red and black of the T & E together at one switch.
- Using a multimeter or continuity tester, measure between red and black at the other switch.
- If no continuity, one of your joints has failed.
- (If you don't have a tester you need to get hold of one)
