Two wy switch Wiring (Iv seen the How to etc)
No, I keep saying - In the diagram the yellow is used for the common.
YOU are using the red as the common.
The reds will have to be joined in a connector.
Therefore YOU will have to put the yellows and blues in the intermediate switch.
The wires do not know what colour they are.
We do not use wire nuts in Britain but I suppose you can if you want.
I'm thinking you should employ an electrician.
Bas is right.
I know the Com cable red. So im guessing as the switch wont be used that the blue or yellow will act as the black wire in the original switch.
I just need to test which one it is and use that.
Why you messing about using an intermediate
Sorry for sounding thick, you are correct.
I forgot that the red was the common in the switch in question (im not at the house now) and wire nut is me mistaking my terminology again. I meant a connector not the screw on type.
No worries anyway I have my head round it now eventually cheers. My main confusion has come from the use of an intermediate this is my first attempt at 3 way switching and was more the focus of my last question.
:eek:
As for the reason for using the intermediate, it seemed that it was the most future proof option as I dont know the exact status of the existing switch. But I do see your point and very much appreciate the advice.
