I've just ordered an EV, which I expect to be delivered in a few months, so I'm now looking into having an EV charger installed.
I've read that a Type A RCD must be used in the consumer unit rather than the older Type AC RCD. Just checked and my consumer unit contains two Hager CD 263U Type AC RCD's, so it looks like these will need to be replaced.
So, is this classed as "work" that will require the current regulations to be applied to my consumer unit? In 2014, exactly 10 years ago no, we had a new plastic Hager consumer unit installed as part of a kitchen refurbishment. I'm aware that a metal consumer unit is now "flavour of the month" and I seem to recall reading that if any work is performed on a consumer unit, it must be upgraded to current regs, which potentially means replacing the plastic CU with a metal CU.
Is this the case or could the EV charger installer (or another electrician I might employ prior to the charger being installed) simply replace the Type AC RCD's with Type A RCD's with no other changes required (assuming everything passes the testing).
I'm also aware that it may be good to have the electrics tested, since it has been 10 years since the last upgrade. Another reason why I may use a local electrician rather than the EV installer.
