Anyone have a link to these regs?
So VC, what does this open flue look like?
What do I order in the merchants?
Tony
Haven't got anything current at home other than my old out of date version of BS:5440 Pt 1.
http://www.scribd.com/doc/65173138/77/Flue-Chimney-Classification might help a bit
It isn't an open flue if you mean the appliance flue Tony it's our old Uni-Flue 60/100mm.
I looked at the MI and it gives no indication of how they want it left other than the standard flue terminal grill. I'd check that with technical because I was always told the air duct is finished flush with the surface of the duct and the terminal left protruding out into the duct to a depth specified by the manufacturer. We show an illustration with a standard terminal which I don't think is correct in a duct.
Go to page 12 of the MI for flue part numbers. http://www.vokera.co.uk/wp-content/uploads/2011/12/compact-28se-user-and-installation-manual.pdf
If you're doing one - when the old boiler comes out block off the flue hole until the new is fitted because of course you are opening the property to a flue system. Sorry if I'm stating the obvious.
