Hi all,
Hope someone can answer a quick question for me. Am I right in thinking that an UFH manifold assembly and pump assembly are typically 210mm centres? So a measurement taken from the centre of the feed fitting to the centre of the return fitting should be 210mm?
I've just had a Reliant underfloor heating pump+mixing valve assembly, and a Reliant manifold delivered. But the pump assembly and manifold don't seem to fit together! The pump assembly was measuring 210mm, but for some reason the manifold was 220mm. I've been on the phone to the supplier and they're going to collect and see what they can do, but just for my own sanity.
Thanks,
Russ
Thanks,
Russ
