Hi all.
Appreciate some advice on this, I haven't been able to find exactly the right answer on other posts.
I would like to replace some under cabinet lights I have that are wired to the lighting circuit controlled by one of the three wall switches (single box with three switches, controlling two main lights and these under cab lights). The under cabinet lights are wired to a junction box mounted beneath the wall cupboards.
The new lights I would like come with a plug and a little transformer box. Can I chop off the plug and wire the transformer to my junction box and mount this underneath the cupboard?
Can anyone advise me the best way to go about this from start to finish? Something like - remove existing lights, check voltage at junction box with multimeter, wire new lights to junction box?
The transformer on the new lights I would like has a 240V input with 12 V output on an 80VA transformer. If I went for fluorescent tube lighting do they require transformers also?
Thanks in advance for any advice you can give.
Cheers.
Cheers.
