I'm looking for some advice regarding the installation of under cabinet lamps and a transformer which I purchased from TLC some time back. The lamps are 20 Volt G4 and the transformer is a Varilight YT150Z.
Initially I was going to use 5 lamps but this will now be increased to 9 in total, in 'blocks' of 3 ( 3 on one wall, 6 on the other wall at right angles to the first but split into 3 lamps on each side of the extraction hood). The transformer was to be mounted in free space above one of the kitchen units from a double socket which presently has the extraction hood connected to it.
I had intended controlling the lamps by using a rocker switch mounted to one of the light units on the low voltage side.
I would really appreciate your advise on how I should proceed with this installation regarding wiring to the transformer and then to the lights. I'm assuming I will need to purchase a further transformer considering the additional load The YT150Z transformer has sets of output terminals and I would appreciate some info on how these can be used.
many thanks in advance.
