Under counter lighting
Thank you for clarifying.
I had no idea that it was absolutely impossible to package a LED power supply into a wallwart, and that not one example of that can be found on sale anywhere.
Of course LEDs can be supplied via a (correct) wallwart. But in this case that would not be suitable as you should not put a 13 amp socket on a lighting circuit. Especially in a kitchen when someone is likely to plug a kettle into it.
You can power most LED strips and lamps with a wallwart or other DC power supply of the appropriate voltage and power. Raw LEDs and a very few LED lamps require a special current-controlled power supply referred to in this context as a driver. Generic DC power supplies such as your typical wallwart are sometimes referred to as an LED driver when used to power LEDs, but they aren't doing anything special. The real driver is inside the LED lamp or strip itself.
LED lamps (ie. light bulbs) will usually, but not always, include rectification as well as smoothing and current-control components. This is almost universal on mains voltage lamps, but also common on 12V lamps since they are usually used to retrofit with a transformer that supplies AC. LED strips don't work with AC and require a DC supply, but do include current-limiting circuitry - usually just a resistor, but occasionally a couple of transistors.
Guffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguffguff
Opinion, mate. Something you quote.
My opinion is that you post a load of guff.
