- Joined
- 29 Jan 2010
- Messages
- 28
- Reaction score
- 1
- Country
Hi Matty
The installer did not add a vapour barrier. Just the underlay.
If there was an effective vapour barrier and the screed had a high moisture reading, would the screed eventually dry out and where would the moisture escape to?
When screed is drying, I take it then that the surface will be significantly drier and may mislead that the screed is dry enough?
Have you any experience of screed drying times with UFH switched on? Does this lessen the 1mm per day?
The damp meter I'm using isn't very sophisticated. Just the el cheapo Draper 2 pronged effort which I find useful for an ameteur poke around It gives the high pitched constant tone on the dark brown bits of flooring. It gives no tone at all on the adjacent boards that appear normal.
I think you may well be right about the moisture getting up between the underlay sheets. I can't figure though why the same screed in the old rooms of the house is not showing the same issue. These boards are 100% so far. As said, the only real difference here is the UFH plastic strips are orientated perpendicular to the planks.
Cheers, Andy
Cheers, Andy
