OK thanks. I have been looking at thermal stores etc and am pretty confused! I already have an unvented DHW cylinder (Gledhill torrent) I presume I don't have to get rid of this? the buffer tank is just an empty cylinder with tappings, the hot water from the boiler goes into this the I have a tapping to go to the DHW cylinder, Another tapping to go to the UFH and a third tapping to go to the rad circuit, the primary fluid is therefore the same for all. Or do I get a tank with a coil, so the boiler goes through the coil then indirectly heats the water in the tank and then the same tappings as above. If I use the method with a coil, then the pump in the boiler covers that bit, the pump in the UFH covers that bit and so I will need a pump for the DHW and Rad circuit, is that right?
