SWMBO wants to change the current carpet tiles in our Kitchen.
One of the options includes electric underfloor heating.
If we proceed then I am aware of Part P and LHBA notification requirements that meen I must pre notify if DIY or use an accredited electrician.
What I want is confirmation - or otherwise of the alternatives.
THere are currently two rings and a cooker radial feeding the Kitchen
Cooker is electric double oven and Gas hob pluged into Cooker outlet. (RCD protected)
Ring One supplies Dishwasher, Washing Machine (both Cold Feed), Tumble dryer and several sockets.
Ring Two supplies Fridge, separate Freezer Kettle and Several sockets (RCBO protected).
As I understand, it there is insufficient capacity in any of the circuits to add the heating system (currently estimated at 1050W, but max 1500W) except possibly the Ring Two but not enthusiastic about this as the risk to Fridge/freezer contents if fault occurs when unattended.
This means - I think - new circuit from CU. There are spare ways on the non RCD side - so would need RCBO. THe only way to get cable from CU to kitchen is to go outside. This would seem to need SWA - unless normal Twin/E in black plastic conduit (such as this http://www.tlc-direct.co.uk/Products/MT20HGB.html) is acceptable.
If this is correct then SWMBO may well loose interest in this option.
Many thanks
Many thanks
