underfloor heating means thermal store a good idea?
3 Oct 2006
Hampshire
looking through some old posts it looks like thermal stores are a contentious topic, however none of the topics I could find discussed their use in conjunction with underfloor heating. A couple of the underfloor heating companies I almost went with strongly recomended their use. (Nu-heat and Chelmer). I eventually went with a different company but am still intrigued by the possibility of a thermal store.. partly because I can install it myself, partly because I would like an easy way of adding solar at a later date and partly because I was told that it was a more efficient way of running underfloor heating..
I'd be grateful for any thoughts on this - especially from anyone who wouldn't normally use one when CH was via rads but might if using underfloor?
many thanks
Trev
As a registered solar installer I would recommend an unvented twin coil solar cylinder, as large as possible rather than a thermal store.
The most efficient way to use underfloor heating is with a condensing boiler as the water temp in underfloor is so low that it helps the boiler condense more of the time thus increasing efficiency.
I would no longer go anywhere near a thermal store for small scale domestic use. They sound a good solution but they are not efficient if used with gas or oil, and they have many disadvantages and few advantages. They are useful if you have a very large one and have a log boiler.
Solar heating is a rich mans toy. You may save £100 a year on heating water. Contrast that with installation costs. If you want to cobble some radiators together to form a collector, then you might get a reasonable return on the investment.
so am I right in thinking that the suposed benefit (stops boiler cycling) has been rendered irrelevant by the blend valves that underfloor heating peeps now have to return water at the right temp? or is cycling still likely?
am a little uncomfortable with the idea of pressurised tanks and the service charges sound quite high, (I'm assuming I can't service it as it is pressurised?), hence the interest, can you tell me why you wouldn't go near one oilman? (there seems to be so much conflicting info on this subject and so real world experiences would be of interest!)
was just looking to future proof where solar is concerned - now that B&Q are selling panels I figured it couldn't be 'that' long before prices start to tumble (well overdue in my humble opinion) also was considering the diy collector route - microbore copper painted black on ally in glass fronted box etc (think I found a link to how to do it on here) however such 'tinkering' type projects will have to wait till I've built the house! :)
thanks
Trev
A properly fitted underfloor system will still only let the boiler fire when there is a demand for heat. it wont cycle unnecessarily. pressurised cylinders that I fit only need prv valves tested annually. Can be done at same time as boiler service :)
Theres much more to an efficient solar heating system than your diy ideas :rolleyes:
thanks for the info on underfloor and servicing gas4
realise this, but until there is either government insentives such as reduced council tax/rates (like in germany) or a solar system cheap enough to pay for itself and its maintenance in a reasonable amount of time I can't justify the expense of a full system. In the mean time it would be an interesting hobbiest project to see how much heat you could get out of a home made panel, this was not meant to suggest it could in any way compete with a professionally constructed and installed panel - if only I had the cash :(
Trev
I take your point on subsidies. At present Solar Trade Association is lobbying MP's and government to increase funding. This months funding budget ran out in 20mins on March 1st :mad:
Please elaborate as you seem to know enough to know there is more to it ...
Why? (As trev asked above I know, but would be most interesting as to why).
Am interested in both solar and themal stores.
Like trev I would not consider paying for one of the professional systems of solar but it would be fun to play around (interetsingly I was considering paying for a thermal store at some point but oilman's comments made me think twice). Actually, with solar I could possibly try one of the evacuated tube systems from Navitron.org.uk which are not too pricey. In any case they do have a great section in their installation manual, which is more like a product brochure than an installation manual, but still really detailed, which explains their take on the development of evacuated tube technology - they claim it was actually developed by some chinese university (beijing I hintk) - and the wording seems to suggest this is all evacuated tube technology not just the one they use. If Navitron are to be believed then all evacuated tube systems are based on this Chinese template making a criticism by an installer that Navitron were "Chinese rubbish", that I think someone on this forum reported, a bit beside the point.
For those interested trev was referring to a flat plate collector which I believe does not collect as well in winter as evacuated tube but would work well in summer. The link he was referring to was probably this. There is another similar one at diydata.
I haven't been able to find any good threads on this site about making your own solar hot water collector; I mean they don't even link to any of the great resources elsewhere on the web - I did see one post that mentioned he had been inspired by some links he got off this forum but couldn't find the post he got the links from. I have seen a few threads with people who claim to have built a system but sadly I haven't seen any reports on the details of how they worked/how they did it. Anyway, a good place to find links on real DIY solar heating (i.e. building it yourself), as well as just self install, and lots of other good "energy saving" stuff is at builditsolar.com.
From my limited understanding so far the one thing you really have to be careful with following some of these plans is that sometimes they don't put in any saftety margin for when the water can boil and the steam get to really high temps. Desiging some pressure release into the system is probably a good idea.
The above notwithstanding, making your own evacuated tube would be a fun project I think. Maybe start simple, do a test with a bottle and a cork with a hole through and two tubes in - one the collector the other to create the vacuum which you could then seal off ... oh yeah you'd have to be careful for implosions or explosions...
Well, that is at the extreme end, as said above if Navitron are right there was some serious and genuinely professional development put into evacuated tube design (but now the patent is out you could try and copy it at home with care) - I wouldn't be surprised however if alot of the flat plate systems aren't extensions of someone's eccentric DIY idea.
Well with flat plate DIY you should be able to get something useful without major experimentation (as people have already explained in detail how they've done it). So on the contrary Trev if you read those plans they say in this technology at least you should be able to get very near if not better than ready made commercial units.
It is a pity solar systems cost so much and why on earth are government grants only for professional installers? If you can make something yourself, say out of freecycled stuff (as someone mentioned he did mostly) and even if it only gives you 25% of your hot water in summer (I think most of the DIYers I read got more than that), then you should get some kind of benefit from the authorities concerned with energy saving (like the German council tax reduction for instance - I wonder if htey say you can only get it if your system is professionally installed, or does it just have to meet some energy efficiency test - interesintg research to do) - instead the money is lining the pockets of quick thinking solar startups many of which are probably making unnatural margins. Trev and gas4you, not just about increasing subsidies but rationalising their allocation - if a company charges ridiculous amounts then the subsidy can be alot and there is little incentive to the home owner - it probably both drives average subsidy prices up and reduces demand for solar power. If you promote more thrifty systems in the first place and pay smaller subsidies towards those you probably get far bigger energy savings. So really ironic that the Solar Trade Association lobbying for more grants - the high prices of their members are not helping. Renewable microgeneration seems to have a good pedigree of genuinely committed greeny types doing inventive and actually useful things in a simple manner. The government could deal on this level - like funding research into how such items could be made with more standardised materials (for instance the CAT has a good book on solar DIY but you have to pay for it - why doesn't the gov fund them so they can give the books away free), as well as or instead of with bodies like the Solar Trade Association.
And of course, a DIYer could potentially install a manufactured.system to the same level or better than a professional installer, and a professional installer could install it worse than a DIYer, so why not just have a governement inspection (and overall energy efficiency assessment) of completed work to qualify for the grant (that would trap the rogue professional installers too)??
Still, it still might be not good environmentally speaking to have any encouragement of solar - maybe the material and installation costs in energy will outweigh any savings - I haven't seen any sutdies, I'm sure there are some. But the freecycle route would be better, and one would think that using more readily available manufactured new parts is more energy efficient than systems which use specialised manufactured parts.
One big advantage of making it yourself as well as installation costs would be ease of repair as you have the parts readily available. If one or more of your tubes broke in an evac tube system (cos tiles fell on them or something) and the manufacturer made your model obsolete you'd have to replace the whole thing.
p.s. also practice of collecting heat might also be used in other situations such as recovering heat from drains or vents, and once you get an understanding of the basics you could apply it to many situations as you think of it (builditsolar had some good links on drain heat recovery - seems silly to do solar and not do this) - the pluming could get very complicated though!
Some people spend too long on the internet and forget that it a place where anyone can claim to be King. You will read all manner of conflicting opinions, the Chinese story is a good one. They have been known for years as leaders in energy conservation. :LOL:
If you really are going to build your own solar/UFH/Heatbank, don't design it on an internet forum, because you will end up with a mongrel dog.
You expect a grant but want to design the system yourself. You want it to be efficient (but have no experience) but also rule out any type of solution that requires skilled annual maintenance.
Since the taxpayer is the one who you expect to fund your exploits (and I, in common with many here are in that club) , I hope you don't get a grant to play at reinventing the wheel.
If you want subsidies for solar move to Scotland get everything fitted at government's (sorry UK tax payers) expense rip the lot out and bring it home.
I think ufh off thermal store is an OK idea.
Sorry, the car antifreeze is ethylene glycol. That should not be used on solar because of the degradation at higher temperatures.
Propylene glycol is less poisonous and better at high temps but more expensive.
A gravity system looks attractive at first but has no protection from stagnation and boiling. Venetian blinds on half the area will not do the job!
The drain back system is simplest and works well and needs little attention.
The Chinese tubes are considered to be poor build quality but most supplied are apparently made in China. There are two basic types.
Tony
A thermal store is much superior. Have the CH section at a lower temperature than the upper DHW section. Unvented cylinders are a silly idea with UFH.
Your knowledge of thermal storage is limited to say the least. The Germans are really turning onto it.
DIYing solar is cost effective.
Boiler cycling can be eliminated easily.
There is far too much ignorance about thermal storage.
thanks
Trev
..and cost £60 to £100 No thanks.
Learn more about thermal storage.
