D
Doctor Drivel
look at this thread and advantages and disadvantages of thermal stores.
//www.diynot.com/forums/viewtopic.php?p=385005#385005
The problem is that far too many people are out there knowing sweet FA, with little intelligence to analyse what is in front of them
simond said:Believe him at your peril, he has no tools to come out and help you. Only a pile of brochures and an overactive right hand.
simond said:Most of this thread linked above was hijacked by Water Systems, aka Doctor Drivel.
Water Systems (Drivel) wrote this, and I would suggest that it describes him perfectly.
kevindgas said:can't agree with the thermal store being better than unvented
the thermal store loses working temperature very quickly the minute water is drawn through it. my experience is the unvented cylinder holds a workable temperature for a longer period.
all the complaints that i have dealt with have been thermal stores that had been installed by 3 now defunct companies i have never been to a complaint about an unvented cylinder
Agile said:At first sight that sounds like nonsence but I can explain what Kevin means!
An unvented is tall and thin and hot water taken from the top will be at the stored temperature until you get to the last 10% or so when some mixing occurs with the cold inlet water.
The thermal store outputs the stored heat from a coil neat the top or a pumped plate HE and the whole store contributes to that heat transfer.
If the store starts at 80 C then when half the heat has been taken out the store temp will have dropped to just 50 C. At such a low temperature the differential of about 10 C across the HE will mean that the maximum output temperature falls to just 40 C.
