clf-gas said:Very easy, have you got somewhere for the manifold to go though.
Balenza said:clf-gas said:Very easy, have you got somewhere for the manifold to go though.
Why would he need a manifold ?.
Also ,wont the roomstat just shut the system down if up to temp leaving the UF section barely warmed up due to the time lag.
clf-gas said:Balenza said:clf-gas said:Very easy, have you got somewhere for the manifold to go though.
a manifold is required becuase underfloor runs at lower temp, have you watched what a boiler does with the room stat.
what do you do for a living.
gas4you said:Why do you assume clfgas is ripping people off by letting you know the correct way of installing underfloor heating.
Underfloor area needs manifold and seperate pump assembly as well as individual room stat. Water for underfloor will be mixed with return water to lower temp around circuit. It is not like adding another rad
clfgas, I wouldn't bother trying to help op as he seems to think we are all rip offs, even though we give advice on here for free
I would let him f*** it up for himself
Balenza said:gas4you said:Why do you assume clfgas is ripping people off by letting you know the correct way of installing underfloor heating.
You got it wrong gas4you. Im the one who suggested clf was a rip off.
Balenza, you are talking out of your a***. Keep wearing your stetson and colt 45 and leave the rest of us to put right your c*** installations that will end up costing op twice in the long run.
BES is known widely to supply cheap c*** that doesen't work. We all supply and fit quality components and have to offer warranties with our installations.
