Softus said:What was your previous user name Balenza?
Bigburn
Bigburn said:some references to solutions that he previously implied were so expensive that an installer who used them would be ripping people off.
Balenza said:Garfeild said:Have done this on a combi system by using Rehau gear,and fitting a programmer separate to the boiler.
I fitted 2 zone valves,1 for the existing CH system,and the other purely for the UFH,which, is,of course controlled by its own stat.
I used a standard programmer,with heating ( to radiators) controlled by the heating channel.
I connected the UFH to the HW side of the programmer,being a combi,the HW is on all the time anyway,so we didnt have to worry about that.
Works a treat.
What size was the UF area Garfield.?
Can you give any costings ?
Softus said:Bigburn said:some references to solutions that he previously implied were so expensive that an installer who used them would be ripping people off.![]()
Bigburn said:Where did I write that?
Bigburn said:clf-gas said:Bigburn said:clf-gas said:Very easy, have you got somewhere for the manifold to go though.
Why would he need a manifold?
Also ,wont the roomstat just shut the system down if up to temp leaving the UF section barely warmed up due to the time lag.![]()
a manifold is required becuase underfloor runs at lower temp, have you watched what a boiler does with the room stat.
OOh I get it. Seems OTT for a bathroom though. Bet you have ripped off more than a few people doing something like this I bet.
Softus don't rises to this p***k he has'nt got a clue about UFH and as I said beforenthis pillock cant spell bellender.
Please explain to everyone who knows less than you why the floor area is a factor.Balenza said:You did,nt (sic.)even think to ask how large the floor area is under consideration.
Please explain to everyone who knows less than you why a manifold is not needed for a floor area of only 2m², or why it is needed for a larger floor area.Balenza said:If the floor area is in a bathroom it may be only 2 sq /m.
That hardly warrants a manifold let alone hydronic UF heating.
Softus said:Please explain to everyone who knows less than you why a manifold is not needed for a floor area of only 2m², or why it is needed for a larger floor area.Balenza said:If the floor area is in a bathroom it may be only 2 sq /m.
Bigburn said:Now the best you can come up with is insults and bad manners.
Bigburn said:Your not a professional and never will be.
Your just some sad assed tozzer who gets kicks nitpicking other peoples posts.
