non compliant to have two RCDsWas it?
I recall the meter installer's boss saying at first that two RCDs were not compliant.
Lower Ze, but that's it. A fault to earth is unlikely to trigger overcurrent devices on a TT supply, but may on a TN-C-S or TN-S supplyHi Securespark,
What advantages over TT does TN-C-S have?
Thanks!
No, it's non compliant not to have 2, as it's not adequate separation of circuits. Perhaps the objection was that there was no single main switch to isolate the whole installation.Was it?
Yes, I know that's what you said they said.non compliant to have two RCDs
Which is why I asked if it was non-compliant.
The man in the office with the authority to over-ride the decision of the meter installer told me that having two RCDs was the reason the meter installer was justified in not installing the meter. Does this not suggest that having two RCDs made the installation non compliant with the regulations in force at that time. ?.
What I make of that is that it is quite possible that the regulations did not prohibit having two RCDs.The man in the office with the authority to over-ride the decision of the meter installer told me that having two RCDs was sensible when safety on site was taken into account and for that reason the meter installer would be told to install the meter. Make of that what you will.
Well, I don't have the "information", as in an answer to my question.Now you have the information there is no need for you to ask for the information again.
Does anyone here other than Bernard know if it was?it was non compliant to have two RCDs
No. While nothing is specifically mentioned about split load or any other type of CU, the applicable regulation states 'one or more earth-leakage circuit-breakers'.What I am getting at was did the 14th Edition forbid having a split-load CU with 2 RCDs?
Thanks.No. While nothing is specifically mentioned about split load or any other type of CU, the applicable regulation states 'one or more earth-leakage circuit-breakers'.
Two or more was probably an unusual arrangement at the time, but was permitted.
