Hi, I have recently moved into a new house and replaced the outside tap as the old one was damaged and didn’t have a check valve installed as the pipe just came straight off the kitchen tap supply. I got rid of what was there and fitted a dishwasher connection point, new connection to the kitchen cold tap and double check valve + isolating valve that feeds the outside tap. I would also like to send a feed into a concrete shed in the garden about 5 meters away. My questions are what regs do I need to follow to be vaguely in compliance and not have the pipe freezing in the winter!
# I would like to use 15mm plastic pipe and bury it in the ground. Is this ok and how deep does it need to be please?
# Are push-fit connections reliable for outside use? I have heard they are generally pretty good and might be less likely to burst in the cold as they are better insulated than copper pipes and can tolerate more expansion of ice in the pipe than copper.
# Finally can they go straight in the ground or do they need to be inside some form of conduit?
Any help much appreciated.
