Uneven wall
3 Dec 2009
Yorkshire
Hello
On saturday I skimmed a wall but looking at it the top half slopes backwards!
Now I intend to fix it and get it level-ish, but I'm in two minds on how to do it. Do I:
1. Hack off the multi finish back to the Hardwall, apply another coat or two of Hardwall to bring it up to level and then skim wall
or
2. Apply two or three coats of mult finish on top of the skim, bring it level and then skim wall?
However a wardrobe will be put there so I'm not fussed about irregularities at the bottom. The top half of the wall will still be visible though.
Phil
Apply PVA first.
Ok thanks for your help. So let me get this straight - hack off skim back to backing plaster? apply PVA, bring upto level with Hardwall then skim!
So far I've skimmed 2 walls and they have been fine. This is the first time I've had to add more Hardwall to level things up after I've skimmed!
Phil
Put a long level in the corner and get it level then put a pencil line up and use that as a guide, just work to the line... ;)
Well to be honest i did think of that, great minds think alike :D
Just another quick question...when i removed the old skirting boards theres a gap at the bottom of the wall. I just need to stick some plaster there for the new skirtings to stick to. However does it matter if its hardwall or multi finish?
Thanks, Phil
Just use hardwall if you have it. Try your new skirting in posistion you might not need anything behind it, fix it and caulk the top if it's not too big a gap....
If you have to put hardwall on it ,trowel it on and get yourself a short piece of wood to screed it. Keep the wood tight to the plaster above skirtin' height and with a sawing action move along the wall and take any excess plaster off where the skirt will fit and fix skirts on when dry ,No probs... ;)You could use Sticks like Sh## adhesive.. Probably the best adhesive on the market. You can also get clear stuff now....
