Hi I found this cable in a property, it looks like armoured on the outside, ie black sheath but it does not appear to have any armour as far as I can tell so far. Also it appears to have a 25mm approx centre core surrounded by separately insulated stranded neutral conductor which I assume add up to the same as a 25mm red conductor.
As for the earth I cannot be sure where that figures into this cable, ie a red centre core surrounded by the neutral sort of sounds neat but obviously the earth would muck that neatness up. If I could cut the cable I could easily see its configuration/layout but i don't want to do that if it is ok and can stay.
With a 25mm cable I would assume a 16mm earth but its difficult to be sure and could be a 10mm earth. also it looks like it may be sleeved.
Please look at my picture and tell me what ever you can about it.
Any help appreciated.
