Just quickly scanned this post so apologies if I've missed something. If your boiler is solid fuel you can't run an unvented cylinder from it.
Interesting thread. Since when have accumulators been patented? Does this mean only one company's accumulators can be fitted only buying them off one company. Accumulators have been around for years and many companies make them.
I am confused a little.
An accumulator used as an top up vessel for an old or problematic heating system works very well indeed.
There appears to a lot of confusion regarding accumulators, mostly with some people thinking the have them on the heating system, this is an expansion vessel and has nothing to do with the patent, to clear things up the following is exactly how things are at present regarding accumulators:- The patent is not on the accumulator as there are many manufacturers, the patent is on the application, if you use an accumulator to boost the water flow in any way this is protected by the patent and is iilegal to use anything but the authorised product.
