I have just looked at a unvented cylinder with pressure problems. The customer called me in asking me to fit a pump on the mains but the mains pressure is 2.5bar and flow rate over 22l/min which should be fine for an unvented cylinder.
The problem is that when the two showers in the house are used there is a slight drop in pressure. However, in the coach house if the shower is run the supply to the showers in the main house stops completely. This has been a problem since day 1 of the installation(installer refused to return once he had his cheque!), has anyone ran 3 showers off of UV at this kind of pressure?
As this has always been a prob I thought the expansion vessel or blocked line strainer shouldnt be an issue although should have checked them on 1st visit I know! Also, pressure on hot outlet is fine so I think blockage would not be the prob.
So...2.5bar enough for 3 showers?.....ex vessel?.....pump it?
Any thoughts appreciated. Cheers.
