Enough and from a verified source. ( not in public domain so I cannot reveal it )Not as much as you like to think though
I'm with bernardgreen on this. I don't like the thought of having a pressurised system in my house
Look up a hot water only thermal store cylinder. Water stored and heated at low pressure, a high pressure coil gives instant heating to the incoming cold water. So high pressure main water pressure at the taps.Same here. Far better flows from gravity. The new age plumbers have lost sight of the benefits of gravity.
And no pressure vessel wanting to blow joints off and flood the home.
Find out the difference of an unvented cylinder to a hot water only vented thermal store.Its no wonder dans opinion of your advice is so low, you would actually fit a vented cylinder, plate heat exchanger, pump, flow switch, tank in loft rather than an unvented cylinder ?
I do like to have fun myself, but didn't Intergas make a thermal store of some description?So many assumptions. So little knowledge. Reading some of the member's posts are comedic gold.
Where would I find that nugget of pure gold , is it a secret like bernards source?Find out the difference of an unvented cylinder to a hot water only vented thermal store.
Plantpot, what was that boiler and combined cylinder they made?No, you idiot.
Just one maker. Many around.....Where would I find that nugget of pure gold , is it a secret like bernards source?
It was under a rebadge named Atmos. Here it is Plantpot. I don't know what sort of cylinder it is, but a combined cylinder and boiler. I never looked:In not sure what side of stupid you're going to land on here... epic.... or embarrassing. They didn't make a thermal store.
Plantpot, all Intergas boilers were Atmos. That was an Atmos. I never read the document as I couldn't be bothered.You fecking retaard. Atmos wasn't intergas.
