That is better.
It is this one:
http://www.plasson.co.uk/gallery/upload/Product Information/Plass4_Data_Sheet.pdf
You have blue MDPE supply pipe, possible 25mm incoming main. Possible replaced lead water main in the past.
What I would is remove that and replace with plasson stopcock onto blue MDPE and 22mm into stopcock.
Daniel.
That's perfect, many many thanks for your help. Yes I suspect the pipe was replaced because the road shows signs of a trench having been cut from street valve to the pavement.
Thanks once again for your help, all.
