I have had a Gledhill Torrent thermal store installed, providing hot and cold at mains pressure at all outlets. My incoming supply is a black alkathene pipe, installed in the 1960s when the house was built. From there, a 15mm pipe runs to the thermal store, with a branch to the kitchen cold tap. The pressure is quite high (over 3 bar).
I have two thermostatic mixer showers, to which I have fitted Mira Eco shower heads, which provides an excellent shower (flow rate of 7-8 litres per minute) when only one of the showers is used and no other water is being drawn off.
I have reduced the impact on flow to the shower of other draw offs by fitting flow regulators to the basin taps and toilet cisterns (all capped at 4 litres per minute).
I now wish to make further adjustments to enable two people to take showers at the same time without a significant drop in flow. I realise that the best solution would be to have a new water supply pipe installed from the meter to the stopcock, together with upgrading pipes internally, but the cost and disruption would be too great.
I am wondering whether there would be any benefit in replacing the 15mm pipe between the stopcock and the Gledhill Torrent with a 22mm pipe which would then branch into two 15mm pipes, for hot and cold supply, at the inlet to the Gledhill Torrent. Would this improve the flow rate, or would it have no effect at all?
