UPS3 pump settings - radiators slow to heat up
24 Oct 2023
I have a UPS3 Grundfos pump and it says I should
Use PP settings for a 2 pipe system. I have selected the higher PP II setting. I have 16 radiators of which 5 are doubles. The radiators take a long time to get fully hot.
Is the PP II setting ok or do I need a faster setting?
Thank you.
could be the boiler needs rating to suit the system if they produce to much heat early on the boiler can shutdown. Or a circulation issue
