I'm replacing a gully and PVC 110mm pipe into clay pipe of a soakaway along side our house at the front of the property. The soakaway pipe was damaged and filled with roots.
Running along side the original clay soakaway pipe i've uncovered what I believe to be the Gas supply pipe. (The electricity is on the other side). Both about 12" depth.
What I think is the gas seems to be about 1.5" diameter but varies due to corrosion or the collar joiners corroding if that is causing the variability.. There is delamination.
Not sure how safe this is. The house is 1920s... Had gas since - anyone's guess but quite a while I imagine. Gas under stairs enters house about 3M further back from where I'm working.
Only other option is water but that is original galv steel pipe too but I think smaller.
Should I leave it or call someone to inspect. If it is questionable will I have to Pay ££££££.
Really appreciate any insight on how these things dealt with before I embark on the unknown...
