Might be daft question....
Just done loads of changes to plumbing in property; relocating bath and sink etc. Had drained everything down.
While I can do such stuff, I'm not overly confident. Rather than starting to fill loft storage tanks straight off, wanted to try and pressure test all my solder joints first. Was going to shut valves off to loft tanks and cap off hot water vent in loft, then apply garden hose (which is mains) to the indirect bath and basin pipes to pressure test. Means less water to drain down if if have to redo and solder joint!
Do hot water vented tanks genrally take mains pressure just for this test?
Cheers,
Neil
Cheers,
Neil
