Hi everyone,
My front door has a Schlage touch-keypad electric lock installed in it. I've found that being able to type in a number to unlock my door is pretty handy, but this thing chews through its 4 AA batteries faster than just about any other electronic I've had. I understand that it's relatively safe to use a higher capacity battery (such as a D cell battery) as long as they have the same voltage. I happen to have a lot of D cells lying around that I don't have anything else to use for, so why not this door?
The problem is space. The battery pack slides in to the lock housing so a D cell doesn't fit. I'm fine with doing a Frankenstein modification, but does anyone have any suggestions as to how I should go about this project? For reference, it expects 6 volts DC so I was thinking of just taking out a AA battery then taping in some wire and attaching the D cell in place of the missing AA battery. The lock unit uses a snap-on like you see with 9v batteries to attach to the AA battery holder, if that also provides any opportunities.
Thanks!
Thanks!
