I'm looking to tile my bathroom with Italian porcelain tiles. The tiles are large and are 90x45 so perhaps heavier than your average tile. Because of this I was advised to remove the old lime plaster which was in places blown as if it didn't the tiles will just fall off.
I've now removed all plaster and are back to solid brick with lime mortar joints. The wall is dusty and has lime on the bricks. To be able to tile I was going to dot and dab moisture plasterboards onto the wall and then afix the tiles directly onto the plasterboard.
However when I called gypsum technical advice they advised me not to use dry wall adhesive on a dusty lime mortar wall as the self adhesive will not afix to lime. Has anyone come across this?? I was advised by them to use battens to afix board too but id like to dot n dab as I think itl be easier.
