I'm thinking of using sheeps wool instead of insulation board as this will fill entire void and has properties that can absorb moisture and but disent allow it to set as condensation.
So I understand insulation boards are not always so good on older solid wall properties as they don't allow moisture to be absorbed, which can cause condensation to set on the wall, sheeps wool allows moisture to be held in the wool but dry away again. It acts as a good balancing material so I understand
