I'm still having probs with this... As shown on one of the pics I put up previously, the boiler has connections for a pump and a thermostat. I've wired up a simple test thermostat (simple on/off switch), which works as expected - turn the switch on and the burner fires up, turn it off and it shuts down. The pump is giving me issues tho - it's constantly on.
Just followed the wiring back for the pump supply terminals and the live comes directly from the boiler "On" switch - I'd hoped it would be cleverer than that!
What are my options - run the pump through the thermostat and risk burning out the heat exchanger as there won't be any overrun? Is the output on the Hive enough to run the burner (115w) and pump (140w) at the same time? Edit - just opened the Hive box and is says on the stat: "Switching power: 3(1)A" - wish it would make up its mind - I need 1.06A!
Or is there some clever device from CPC or Maplins that will provide an output for 5 mins after the burner shuts off? Or maybe I should butcher my bathroom fan?
