I used to lose pressure on my rubbish Ocean Alpha 240P because of tiny leak inside the combi. Because the leaking water was so hot it used to evaporate pretty quickly. That said, the loss in pressure was no where near as fast as yours. I only discovered it when I took the cover off.
/QUOTE]
Haven't noticed any leaks within the boiler, but I have read how this may happen with a faulty heat exchanger and that you may not be aware because there are no easily visible signs
A difficult one, because pressure is very dependant upon temperature - your system would have still had some heat left in it when you topped the pressure up, but I would say from that you do not have a leak.
Now leave the plastic bag in place, run the system normally and see if any water is ejected into the bag.
The boiler is around 7 years old and we don't think it is suitable for the size of property. When we've been looking just in case we need to replace it, and most searches are suggesting a 30 or 35kw boiler.
Grasping at straws now before having to spend lots of money. Could it be the pressure sensor that is at fault?
Returned home today 0.3bar being displayed. The smallest amount of water put into the boiler and its now happily running at 1.5bar
I would not expect so, you are regularly putting water in and the water cannot just disappear, it must be leaking out somewhere. You have more or less proven it's nothing leaking external to the boiler.
