Then you do not have a problem with the expansion vessel. You have a leak. A half competent engineer would soon identify whether it was within the boiler or elsewhere on the system.rwalters said:The PRV valve is not leaking at all.
Putting a new expansion vessel on the wall will do nothing to stop the leak although it will extend the period of time between system pressure drops. The leak will be causing damage to your system so putting off dealing with it is not a good idea.
