I'm about to have my old boiler replaced (Glowworm Spacesaver 60k) with a Vaillant 418. I'm staying with an open vent system and the existing controls (because I prefer simplicity, hot water storage and the controls are relatively new). Can anyone clarify the wiring requirements?
The system currently uses a Siemens RWB9 controller, Sunvic TLX7501 room stat, cylinder stat, Sunvic mid position valve and is wired according to the Sunvic Unishare diagram here: http://www.sunvic.co.uk/uniselect.pdf
Am I correct in assuming that I need to modify as follows:
1. Permanent live feed from switched side of isolator upside of the controller
2. Single wire switched live feed to boiler term 4 (with link removed 3 - 4) from term 10 of the JB on the Sunvic Y plan drawing
3. Remove pump switched live feed from term 9 of the JB in the Sunvic drawing and feed pump only from the pump connection terms on the new boiler
New wiring proposals can be seen here (hopefully!)
//media.diynot.com/130000_129671_16438_21058043_thumb.jpg
