pannierstan said:
Agile said:
The diverter valve is mounted at an angle so you could describe the movement in the vertical or horizontal directions.
I chose the horizontal as I thought that would be the easiest to understand.
Tony
The valve is mounted so the movement direction would be up and down.
Stan
The one I went to yesterday is mounted at an angle of about 35° above the horizontal. I therefore consider I was right to use left-right as it resolves to a greater "y" axis movement.
I was cleaning the plate and ended up with a leaking DHW "o" ring seal with the problem compounded because the DHW valve under the boiler would not turn fully off and there was no stopcock in the house and I had to turn off supply in the street. It did not help that the mains pressure was very high at about 3 Bar.
That was the first time I have ever had a problem with that but looking back perhaps thats just because I have been lucky.
Tony
Tony
