If you do that I will just repeat the reply I gave before!
If you want it solved the normal solution would be to call a competent boiler engineer.
Thats if you have really explained the problem correctly!
The diverter valve fails on almost all of your model of boiler. The symptoms vary because it can stick in either position and will sometimes move or stick so the symptoms change and that seriously disorientates the owner.
There are two basic symptoms but it can also stick in between so will give mixtures as well!
1. No DHW but rads heat when a tap is turned on!
2. DHW as usual but no heating and boiler will cycle to preheat while CH is selected.
Its almost worth changing the diverter because if its not been changed and is the old type with 3 mm holes in the side then its going to fail sometime. And of course I am not totally convinced that you are necessarily describing the symptoms!
Thanks for that Tony - I reposted because I seemed to ber getting variable information in the replies before. I am a technical type and think that I am describing the problem properly - my HW is not hot (just warm - it is being heated but not much) if I turn on a tap and the CH is NOT running - it is hot if I turn on a tap and the CH IS running. I have tested this many times.
I've had this problem before on my own boiler, changed diaphragm washer made no difference (cheapest option) then after some head scratching manually pressed down micro-switch (looked as if it was working) and hey presto it worked, as it was 9 pm temporarily bent micro-switch down a bit, that was 2 month ago still working, so i'm not touching it yet
