Hi, hoping someone can help (Vaillant certainly don't seem able to). I have a Vaillant boiler, with VRC700, and used to have normal TRVs, and everything worked OK. I added the ambisense pack -Internet gateway and 3 ambisense valves- but it clearly isn't working. The simpler issues, with fewer variables; Often, the radiator is hot, even when the room temp displayed in the app is higher than the demand temperature as displayed both in the app and on the valve. In this case, even if the hot water is circulating (there may be demand from another valve) surely the valve in this room, where the room temperature is shown as higher than the required temperature, should be off? The next simplest issue, when the TRV700 controller is warmer than the demand (20c) for the room (it's in another warmer room - 22c), even though the displayed temperature on the valve and in the app is even lower (18c), the boiler doesn't come on; so in this case, it behaves as if the VRC is preventing the boiler turning on.
In case it helps, yesterday when the first situation occurred, I turned that room to "off", and the boiler turned off (the other rooms had no demand -> warmer than required), then I set the room to auto, and the boiler stayed off. (which it should since all rooms where above demand.) The controller was in the warmest room. However today, in the same situation (apart from the controller being in an unheated room), when I turned back to auto, the boiler came back on. Which it shouldn't since all rooms where above demand.
So currently, if I don't keep an eye on it, the boiler is running pretty much full on, flow of 72c, heating rooms that are already too warm, or I wake up to a cold house... and moving the controller just changes the problem.
Help please!
nb app shows no problems, in general I can hear the valves moving, they reflect the temperatures set in the app. (but rooms tend to show about 3c higher than reality in the app)
