Vaillant - AuroStor -twin coil unvented cylinder
3 Aug 2005
Warwickshire
I currently have a Potterton performa 28i supplying all HW. I am adding a forth bedroom with ensuite shower room. I would like the option to run two showers simultaneously and for both showers to have a similar pressure to what we experience today from the combi. Can this be achieved by using the AuroStor or would I have to add pumps and a separate cold water store also?
I am looking at the Aurostor as I would like to add a solar panel also.
Unvented will give you greater pressure at your hot outlets than any Combi, so if you are getting good performances from your Hot water supply now, your unvented will give you Hot water at mains pressure.(Hot water, same as cold water pressure).
Thanks Bamber - I see you like university challenge!!
I think I may get some quotes - Do you know if you can install the cylinder first and fit the solar panel and pipes at a later date?
You must be as old as me ;) I must confess that I am not up on Solar Heating as yet. As far as I can see there is a flow pipe to your Solar panels, which is then heated by solar energy & then a return pipe to your cylinder, heating your hot water/heating. Basically.
I would imagine you would need a different cylinder but I don`t think it would change the overall setup regarding your radiators etc.
the solar pack can be added at anytime to the aurostor twin coil cylinder, however the cylinder should be sized to allow for this. Rule of thumb 35-50litres of stored hot per person and then 50% added to total for solar heating.
Solar will use the bottom coil of the cylinder and Ch the top coil, but if using just CH for the time being it would be advisable to pipe up through both coils until solar added at later date.
The aurostor comes with all the sensor pockets already in place for vaillants solar packs.
Lee
Check whether you will be allowed to purchase Aurostor yourself, as all Vaillant solar products are only available for purchase by installers who have passed the Vaillant Solar/BPEC traing course ;)
Thats what i originally got told, however its never the case you have the cash the merchants will sell.
I installed and commisioned one for a plumber who doesnt hold the qualification. He bought the bits direct from vaillant through his boiler rep , vaillant then gave my number for commisioning if he got stuck.
Remeber vaillant solar is braze or compression, no lead or lead free. ;)
