Dan sorry if these questions sound a bit "dumb" but after years of having a more simpler but old back boiler/gas fire set up it is a bit more confusing to someone like myself who doesn't know the fist thing about plumbing or the likes.Room thermostat needs to be set at whatever gives you least earache as mentioned before.
The heating dial on the boiler needs to be set as low as it can be to achieve the room temperature as per the room stat.
Don't worry about the egg timer unless one or both of the above are not satisfied.
So when it's cold like it is now,where would you have these settings set?
It just has to be warm not boiling hot.
If as I say the room stat is set to 21-22ish does the CH setting on the boiler have to be up full at 75?
Sorry if I'm repeating myself.
I'm trying to work out how best to have the house/room warm without wasting gas as I was using nearly £3 a day just to heat one room(and a tiny hall where the room stat is and the radiator does't have a thermostatic valve so can't be turned off)
Man I preferred the simplicity of the old set up
