I'm really hoping someone can solve a bit of a mystery for me. We have an ecotec pro 28 combi boiler (6 yrs old) & over the last few months we've noticed that the water for our bath & shower have reduced. It started around September. To be honest I thought maybe I'd knocked the dial to the thermostat by mistake & Would be rectified at the next service.
Last month we had our bathroom refitted (& I mean completely gutted) & whilst doing it, the plumber replaced all the pipe work under the floor boards as was over 20 yrs old. At the same time I asked him if he knew how to turn the water temp up. He checked & confirmed the water temp was already on maximum. When the bathroom was finished unfortunately the water was still not hot, just warm ish. The plumber contacted a boiler engineer to look at the boiler & see what was going on. He thought that a cold pipe was too close to the hot pipe leading to the bath & shower. It sounds plausible, but we always had scaulding hot water for the bath in the past, it got cooler by itself without any changes to pipe layouts. He then said maybe it was the heat exchange, but that doesn't make sense either as both the kitchen & bathroom sink water is still scalding hot.
The following things also make no sense:
- the pipe where the water comes out of the boiler is very hot no matter what tap I use.
- if I run the bathroom sink tap & bath taps at the same time, they are completely different temps.
This may be a red herring, but about a year ago we had a leak from the boiler, which turned out to be a cracked overflow pipe, which was replaced & has now been lagged. Other than servicing, no other work has been done on the boiler.
I'm really hoping someone will have a clue what is going on, my husband is talking about replacing the entire boiler. But given that we don't know 100% that the boiler is the problem, it seems a bit extreme.
All suggestions welcomed.
