Hi, i have a vaillant ecomax which is showing an f20 fault code. This is something to do with overheat.
It has been like this for the past week so no way it is overheating as it has not worked. The code will not clear so i am guessing it may be a sensor, i have bought one but do not know which one to change. I have disconnected the wiring to each of the three i can see in turn and connected to the new sensor in the hope it would work without having to actually fit it until i know which one is at fault (if any).
I have contacted several engineers, only one came out and he said he suspects the pump although this is still free if a little stiff. He was going to go away and research it but has not got back to me so as i do not need to touch any gas i thought i would have a go myself. I am perfectly competent.
Any ideas ?
Any ideas ?
