This boiler was removed from a property i built an extension on a couple of years ago. It had only been in use for just over six months and the owner had original receipt and service information etc
He had to uprate or something, i dont know why but it was working at the time it was removed.
Well i never got anyone to fix this, no-one seemed interested. I had a new pump and heat exchanger fitted by an 'engineer' at considerable cost but neither fixed it which i was not surprised with, so i got stuck in myself.
As i mentioned in an earlier post i suspected it to be electrical but obviously i know nothing compared to the only expert willing to have a look.
Changed the PCB and its been fine ever since. I suspect water was leaked on it when it was installed hence it running for a few seconds before it blew.
Thought i would let you know in case you come across a similar problem.
