Have bought a house and inherited a Vaillant EcoMax 835/2 boiler, about 10 years old. Seemed to be working at first.
However it started to give f25 faults and now alternates between f25 and f32. You can clear the fault and then it might work, but sometimes it takes 3/4 attempts.
When set to a timer in evening and overnight, there is always a fault after and it hasn't worked.
I had a heating engineer look at it and he said it was working fine. Could replace the fan for £300 which the f32 relates to, but said Vaillant fixed price is £249 and would cover the PCB also.
Said the f25 was low pressure (pressure seems down a bit but still ok - around 1.3 bar). Cost £55 for this.
Had a look under the cover can't see anything amiss... under panel flap has written new flexy hose a couple of years ago.. best course of action?
Thanks in advance,
chaoticj
Thanks in advance,
chaoticj
