Hello
I have an vaillant ecotec boiler installed approximately 2.5 years ago. The boiler has a magna cleaner attached to it when fitted.
The boiler will fire up for a while and then error codes F23 or F24 will appear. if you rest the boiler, the boiler will work for a while then code appears again. Acording to the manual it - water shortage, temperature rises too quickly.
Could someone please advice what is the best way to resolve this. How much would it cost to repair the boiler.
thank you in advance.
