Why not use the Vaillant vSMART? Connects to eBus, modulates heating from local weather and room temperature, Internet access, job done. You do need a VR65 to operate the zone valves though which you would have if you had a 430/470 anyway.
Just a quick question for someone....
I have a Vaillant EcoTech 637, a VR65 control centre and a VRT392f Wireless thermostat. Its a system boiler with hot water tank. I am told the boiler isnt an OpenTherm. I have two zones, but obviously due to the VR65 only have a single zone output, they are wired together on the junction box and therefore act as one zone.
Can I use this boiler / control centre with a Nest 3rd Generation (so I can control the rads and water tank) Vaillant seem to think "no", as the Nest wont modulate the boiler and I will loose efficiency and it wouldnt control the water ?!!?
Can someone explain what part of my setup does the modulation and controls how much gas the boiler feeds on and why the Nest wouldnt be suitable. I am not sure if Vaillant are telling porkys or not.
As for the Nest - has anyone had this style of setup (VR65 etc...) working with a nest.
Does my 392f just turn the boiler on or off...?
I am led to believe that the VR65 will need to come out and some sort of 3rd party wiring centre put in.... Any suggestions?
I would be tempted to move to the VSmart setup from Vaillant. I have struggled to find from the Vaillant website actually what bits and bobs I would need to install this setup. Will it work with my VR65? Or do I need another control centre?
If I get another control centre, can I get one that I can split my ones into two? If I split my zones into two, can I have two VSmart thermostats - one per zone.
Oh the questions..... too many questions.
Thanks everyone
