Give us a shout next time you have a date
Little point in doing practical tests and that would need a supply of faulty caps.
But you could simulate the effect by adding external resistance in series in your circuit.
The ESR is totally relevant to DP's post on Thursday at 1150 where he says that he measures capacitance.
It is to demonstrate that just because a component may have the correct capacitance value, it may have a high ESR and consequently not function correctly in the circuit.
Electronics is no longer very simple.
Tony
Yes, but if you must try repairing PCBs then you need to be aware of the last sentence of the bold part that I posted.
That a high ESR can present symptoms that may be difficult to diagnose only doing capacitance measurements.
In an ideal world if you are seriously into electronic repairing then you would buy an ESR meter!
If just casually interested you could apply an ac voltage at a high enough freq for the reactance of the cap to be very small and put a variable resistance in series with the cap under test. Then measure the voltage across the cap and move the pot until you get half the applied voltage and then measure the value of the pot.
If you were really interested in ESR then you would buy an ESR meter or simply measure it using simple components.
I cannot spend time teaching you if you don't really want to learn.
It would indeed be a challenge to teach someone who does not want to learn. That's why I so appreciate those who devote their life to teaching wayward youths.
