You've never tried to remove a filling loop on an Ecotec, have you?Which should be removed after the system has been filled. Removing it will ensure that no more water can get into the heating system even if the valves are letting by when shut.
Must depend on the model. Our ecotec pro has standard filing loop, I know that because I had to change it because it was leaking from the spindle.You've never tried to remove a filling loop on an Ecotec, have you?
It is technically removable, but you need child-sized fingers to actually get to itFrom that I assume it is a non removable piece of pipe. What ever happened to the sensible requirement for flexible removable filling loops. Or is there now implicit trust in valves to prevent CH water getting back into the nains supply ?.
Yes, the pro is the no-frills bargain basement version of the Ecotec, and needs an external filling loop. The Plus has one built in to the isolation valvesMust depend on the model. Our ecotec pro has standard filing loop, I know that because I had to change it because it was leaking from the spindle.
Maybe the op problem is that there are two filing mechanisms and one is letting by?
